STM32U0
johannes-lichtenberger
With the STM32CubeIDE I can't debug a firmware, as always the connection is lost:
Download verified successfully
Target is not responding, retrying...
Shutting down...
Exit.
Any ideas?
kind regards
Johannes
STTwo-32
Hello @johannes-lichtenberger and welcome to the ST Community :smiling_face_with_smiling_eyes:.
I suggest you take a look at this Post. It should be helpful.
Best Regards.
STTwo-32
5 REPLIES 5
Uwe Bonnes
Chief
Tell us your hardware? Some commercial board or something you build? Check and test other cables and USB ports. Check wiring. Check your setup.
STTwo-32
Best Regards.
STTwo-32
I've checked using other USB-Ports, but it didn't help. I'm going to check another USB 3 to USB-C cable, but I doubt, that it helps, either. The board is a new STM32U083C-DK.
kind regards
Johannes
Double check with STM32 Cube Programmer.
Any details on the ST-LINK/V2EC model used here?
Thanks, I've enabled the debugging PINs in the Cube / meaning removing them from the unused PINs... so, now it seems it's possible to debug without problems... :)
kind regards
Johannes
