STM32G0B1RE USB_DRD_FS
sravani
Hi everyone,
I am currently working on a project involving the STM32G0B1RE microcontroller and had encountered an issue while configuring the USB_DRD_FS (Dual Role Device Full Speed) in Device mode using STM32CubeIDE.
Here are the steps I followed:
  1. I selected the USB_DRD_FS peripheral and set it to Device mode.
  2. I configured the USB_Device in CDC (Communications Device Class) mode under Middleware.
After completing these configurations, I noticed that the GPIO pins associated with the USB_DRD_FS peripheral didn't appear in the generated code or usbd_conf.c
Best regards,
Sravani
34 REPLIES 34
Hi sir, I sent file in above chat, can you check once please?
hi sir,
"Try: not select > USB_DRD_FS (Dual Role Device Full Speed) ,
but > Device only ."
I did same thing
But am not getting usb port, can we connect on teams for resolve the solution?
sreekantam0427@gmail.com, this is my mail id
Best regards
Sravani S
Hi AScha,
Would it be possible for us to connect on Teams to resolve the issue we discussed? Please let me know a convenient time for you.
You can reach me at sravani.s@esmartinnomatics.com.
Thank you.
Best regards,
Sravani
1. I am at work now, its lunch time, so i have some minutes...but no video/chat equipment at my PC. So..no.
2. I could not tell you anything on video, that i could not explain here.
3. Dont know, what you doing wrong - if i try , set USB-device-CDC on a bluePill board, it just works.
Maybe you should try this first and get it working, to come closer to the problem here on G0B1 .
"Dont know, what you doing wrong - if i try , set USB-device-CDC on a bluePill board, it just works"
ok i will try thank you sir
