STM32CubeIDE generates bad DMA init code for UCPD on G0B1
GrahamAU
I'm using STM32CubeIDE to configure UCPD1 on STM32G0B1KET6N.  My firmware package is FW_G0 V1.6.2
I enable DMA: UCPD1_RX = DMA2 Channel 1, UCPD1_TX = DMA2 Channel 2
The generated code in MX_UCPD1_Init can't compile because the DMA init code is bad.  The section labelled /* UCPD1_RX Init */ should start with this:
LL_DMA_SetPeriphRequest(DMA2, LL_DMA_CHANNEL_1, LL_DMAMUX_REQ_UCPD1_RX);
... but it actually starts with this:
LL_DMA_SetPeriphRequest(DMA2_Channel1, DMA2_Channel1, LL_DMAMUX_REQ_UCPD1_RX);
Compare the first two parameters.  Luckily, the compiler chokes on this and it's obvious how to fix it.  There are 8 lines with this bug for the RX DMA, and 8 lines for the TX DMA.
I don't know if my other UCPD settings influence the bug:
UCPD mode = sink
Dead battery enabled
USB/UCPD1 interrupt enabled
DMA1 4-7 / DMA2 1-5 / DMAMUX1 interrupt enabled
Pins PB15, PA8, PA9, PA10 are all configured for their UCPD1 functions.
3 REPLIES 3
FBL
Hi @GrahamAU
Could you let me know which version of CubeMX you are using? I attempted to reproduce the issue on my end, and the code generation worked correctly. Attached my IOC file for reference.
On MacOS:
STM32CubeIDE
Version: 1.16.0
Build: 21983_20240628_1741 (UTC)
I tried your .ioc and it works fine.  But then I changed the DMA channels to DMA2 (not DMA1) and I get my bug.  Give it a try.
Thank you for your feedback @GrahamAU
A new ticket is reported to MX team. Internal ticket number is 189793
