STM32CubeIDE 1.13.2 macOS keybinding problem
2023-09-27 12:16 AM
I already wrote a about this to pinned release thread, but as there is no public tracker I don't know if that was the correct place, so I decided to a make a new thread.
On macOS, it is not possible to type '@', because ALT+L is hard coded for 'Login'. It is not shown on Settings->General->Keys, so I can't change the binding. I tried to change it from workspace->.metadata/.plugins/org.eclipse.e4.workbench/workbench.xml, but it doesn't matter if I delete it or change the binding to something else, the Login command will be set back to ALT+L after exiting STM32CubeIDE. On first time after changing the binding, the editor crashes.
- Labels:
STM32CubeIDE
2023-11-20 3:49 AM
Strange!!! As you can see in the attached screenshot, with STMCubeIDE 1.13.2 and macOS Sonoma 14.1, this problem does not occur....
