2024-06-25 03:32 AM
I’m trying to use the RTOS Kernel Awareness at my FreeRTOS, Makefile Project,
but the ROTS Proxy throws following errors:
STMicroelectronics RTOS Proxy. Version 0.14.0
Copyright (c) 2023, STMicroelectronics. All rights reserved.
Loading RTOS driver... FreeRTOS
Connecting to GDB server 127.0.0.1 on port 61234 ... Connected
Listen for GDB connection on port: 60000 ... Connected
Data structure member error: xLIST_ITEM
Data structure member error: xMINI_LIST_ITEM
Data structure member error: tskTaskControlBlock
Missing data structure member: xList.uxNumberOfItems
Missing data structure member: xList.xListEnd
Unsupported xList structure
Update threads. Failed collecting threads.
the view "FreeRTOS Task List" is shown and correct.
I use the FreeRTOS Kernel V10.2.1
at an another Project with FreeRTOS Kernel V10.3.1 I have the same problems.
The Proxy also generates a .proxy_cache file in the directory of the elf file.
What configuration am I missing?
What information could help to find the problem?
2024-06-26 07:14 AM
Hello @TWagn.2,
This can happen if the RTOS Proxy is not compatible with the version of FreeRTOS you are using, or if the FreeRTOS configuration is not what the Proxy expects, please check: How to enable FreeRTOS™ Run Time and Stack Usage view
