PSSI SFR not available while debugging (STM32H730)
EKoec
Hey there. I am developing an application which uses the PSSI interface of the STM32H730. But while debugging the registers are not available in the SFR view. Any ideas?
EKoec
Adding..
<peripheral>
      <name>PSSI</name>
      <description>Parallel synchronous slave interface </description>
      <groupName>PSSI</groupName>
      <baseAddress>0x48020400</baseAddress>
      <addressBlock>
        <offset>0x0</offset>
        <size>0x400</size>
        <usage>registers</usage>
      </addressBlock>
      <registers>
        <register>
          <name>CR</name>
          <displayName>CR</displayName>
          <description>PSSI control register</description>
          <addressOffset>0x0</addressOffset>
          <size>0x20</size>
          <access>read-write</access>
          <resetValue>0x40000000</resetValue>
          <fields>
            <field>
              <name>OUTEN</name>
              <description>Data direction selection bit</description>
              <bitOffset>31</bitOffset>
              <bitWidth>1</bitWidth>
            </field>
            <field>
              <name>DMAEN</name>
              <description>DMA enable bit</description>
              <bitOffset>30</bitOffset>
            </field>
            <field>
              <name>DERDYCFG</name>
              <description>Data enable and ready configuration</description>
              <bitOffset>18</bitOffset>
              <bitWidth>3</bitWidth>
            </field>
            <field>
              <name>ENABLE</name>
              <description>PSSI enable</description>
              <bitOffset>14</bitOffset>
            </field>
            <field>
              <name>EDM</name>
              <description>Extended data mode</description>
              <bitOffset>10</bitOffset>
              <bitWidth>2</bitWidth>
            </field>
            <field>
              <name>RDYPOL</name>
              <description>Ready (PSSI_RDY) polarity</description>
              <bitOffset>8</bitOffset>
            </field>
            <field>
              <name>DEPOL</name>
              <description>Data enable (PSSI_DE) polarity</description>
              <bitOffset>6</bitOffset>
            </field>
            <field>
              <name>CKPOL</name>
              <description>Parallel data clock polarity</description>
              <bitOffset>5</bitOffset>
            </field>
          </fields>
        </register>
        <register>
          <name>PSSI_SR</name>
          <displayName>PSSI_SR</displayName>
          <description>PSSI status register</description>
          <addressOffset>0x4</addressOffset>
          <size>0x20</size>
          <access>read-only</access>
          <resetValue>0X00000000</resetValue>
          <fields>
            <field>
              <name>RTT1B</name>
              <description>FIFO is ready to transfer byte</description>
              <bitOffset>3</bitOffset>
            </field>
            <field>
              <name>RTT4B</name>
              <description>FIFO is ready to transfer 4 byte</description>
              <bitOffset>2</bitOffset>
            </field>
          </fields>
        </register>
        <register>
          <name>PSSI_RIS</name>
          <displayName>PSSI_RIS</displayName>
          <description>PSSI raw interrupt status register</description>
          <addressOffset>0x8</addressOffset>
          <size>0x20</size>
          <fields>
            <field>
              <name>OVR_RIS</name>
              <description>Data buffer overrun/underrun raw interrupt status</description>
              <bitOffset>1</bitOffset>
            </field>
          </fields>
        </register>
        <register>
          <name>PSSI_IER</name>
          <displayName>PSSI_IER</displayName>
          <description>PSSI interrupt enable register</description>
          <addressOffset>0xC</addressOffset>
          <size>0x20</size>
          <fields>
            <field>
              <name>OVR_IE</name>
              <description>Data buffer overrun/underrun interrupt enable</description>
            </field>
          </fields>
        </register>
        <register>
          <name>PSSI_MIS</name>
          <displayName>PSSI_MIS</displayName>
          <description>PSSI masked interrupt status register</description>
          <addressOffset>0x10</addressOffset>
          <size>0x20</size>
          <fields>
            <field>
              <name>OVR_MIS</name>
              <description>Data buffer overrun/underrun masked interrupt status</description>
            </field>
          </fields>
        </register>
        <register>
          <name>PSSI_ICR</name>
          <displayName>PSSI_ICR</displayName>
          <description>PSSI clear interrupt status register</description>
          <addressOffset>0x14</addressOffset>
          <size>0x20</size>
          <fields>
            <field>
              <name>OVR_ISC</name>
              <description>Data buffer overrun/underrun interrupt status clear</description>
            </field>
          </fields>
        </register>
        <register>
          <name>PSSI_DR</name>
          <displayName>PSSI_DR</displayName>
          <description>PSSI data register</description>
          <addressOffset>0x28</addressOffset>
          <size>0x20</size>
          <fields>
            <field>
              <name>BYTE3</name>
              <description>Data byte 3</description>
              <bitOffset>24</bitOffset>
              <bitWidth>8</bitWidth>
            </field>
            <field>
              <name>BYTE2</name>
              <bitOffset>16</bitOffset>
            </field>
            <field>
              <name>BYTE1</name>
            </field>
            <field>
              <name>BYTE0</name>
              <bitOffset>0</bitOffset>
            </field>
          </fields>
        </register>
      </registers>
    </peripheral>
... to
STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.productdb.debug_1.xxxxx/resources/cmsis/STMicroelectronics_CMSIS_SVD/STM32H73x.svd
seems to do the trick, no guarantee for correctness, though.
5 REPLIES 5
Markus GIRDLAND
Hello there!
STM32CubeIDE only reads an .svd file to display these registers. I will submit a ticket to the responsible team for further analysis and possible correction.
If this is urgent then you can manually add it in the .svd file by default located at:
C:\ST\STM32CubeIDE_1.6.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.productdb.debug_1.6.0.202102151443\resources\cmsis\STMicroelectronics_CMSIS_SVD\STM32H73x.svd
Thanks for bringing it to our attention!
EKoec
Thanks for your quick reply. If i do a
grep -ri PSSI_CFG
in the respective folder it doesn't return anything so it seems to me the interface registers are missing from all svd files.
You're correct. The information seems to be missing from the .svd files. I went ahead and created a ticket (internal BZ#107070). The team responsible for the updating of these files have been assigned to the ticket.
EKoec
Adding..
<peripheral>
      <name>PSSI</name>
      <addressBlock>
        <size>0x400</size>
      </addressBlock>
      <registers>
        <register>
          <name>CR</name>
          <size>0x20</size>
          <fields>
            <field>
              <name>OUTEN</name>
            </field>
            <field>
              <name>DMAEN</name>
            </field>
            <field>
            </field>
            <field>
              <name>ENABLE</name>
            </field>
            <field>
              <name>EDM</name>
            </field>
            <field>
              <name>RDYPOL</name>
            </field>
            <field>
              <name>DEPOL</name>
            </field>
            <field>
              <name>CKPOL</name>
            </field>
          </fields>
        </register>
        <register>
          <size>0x20</size>
          <fields>
            <field>
              <name>RTT1B</name>
            </field>
            <field>
              <name>RTT4B</name>
            </field>
          </fields>
        </register>
        <register>
          <size>0x20</size>
          <fields>
            <field>
            </field>
          </fields>
        </register>
        <register>
          <size>0x20</size>
          <fields>
            <field>
              <name>OVR_IE</name>
            </field>
          </fields>
        </register>
        <register>
          <size>0x20</size>
          <fields>
            <field>
            </field>
          </fields>
        </register>
        <register>
          <size>0x20</size>
          <fields>
            <field>
            </field>
          </fields>
        </register>
        <register>
          <size>0x20</size>
          <fields>
            <field>
              <name>BYTE3</name>
            </field>
            <field>
              <name>BYTE2</name>
            </field>
            <field>
              <name>BYTE1</name>
            </field>
            <field>
              <name>BYTE0</name>
            </field>
          </fields>
        </register>
      </registers>
    </peripheral>
... to
As a quick update:
This has been corrected and will be part of the next release of STM32CubeIDE.
