2021-05-17 12:44 AM
Hey there. I am developing an application which uses the PSSI interface of the STM32H730. But while debugging the registers are not available in the SFR view. Any ideas?
2021-05-17 2:55 AM
Adding..
<peripheral>
<name>PSSI</name>
<description>Parallel synchronous slave interface </description>
<groupName>PSSI</groupName>
<baseAddress>0x48020400</baseAddress>
<addressBlock>
<offset>0x0</offset>
<size>0x400</size>
<usage>registers</usage>
</addressBlock>
<registers>
<register>
<name>CR</name>
<displayName>CR</displayName>
<description>PSSI control register</description>
<addressOffset>0x0</addressOffset>
<size>0x20</size>
<access>read-write</access>
<resetValue>0x40000000</resetValue>
<fields>
<field>
<name>OUTEN</name>
<description>Data direction selection bit</description>
<bitOffset>31</bitOffset>
<bitWidth>1</bitWidth>
</field>
<field>
<name>DMAEN</name>
<description>DMA enable bit</description>
<bitOffset>30</bitOffset>
</field>
<field>
<name>DERDYCFG</name>
<description>Data enable and ready configuration</description>
<bitOffset>18</bitOffset>
<bitWidth>3</bitWidth>
</field>
<field>
<name>ENABLE</name>
<description>PSSI enable</description>
<bitOffset>14</bitOffset>
</field>
<field>
<name>EDM</name>
<description>Extended data mode</description>
<bitOffset>10</bitOffset>
<bitWidth>2</bitWidth>
</field>
<field>
<name>RDYPOL</name>
<description>Ready (PSSI_RDY) polarity</description>
<bitOffset>8</bitOffset>
</field>
<field>
<name>DEPOL</name>
<description>Data enable (PSSI_DE) polarity</description>
<bitOffset>6</bitOffset>
</field>
<field>
<name>CKPOL</name>
<description>Parallel data clock polarity</description>
<bitOffset>5</bitOffset>
</field>
</fields>
</register>
<register>
<name>PSSI_SR</name>
<displayName>PSSI_SR</displayName>
<description>PSSI status register</description>
<addressOffset>0x4</addressOffset>
<size>0x20</size>
<access>read-only</access>
<resetValue>0X00000000</resetValue>
<fields>
<field>
<name>RTT1B</name>
<description>FIFO is ready to transfer byte</description>
<bitOffset>3</bitOffset>
</field>
<field>
<name>RTT4B</name>
<description>FIFO is ready to transfer 4 byte</description>
<bitOffset>2</bitOffset>
</field>
</fields>
</register>
<register>
<name>PSSI_RIS</name>
<displayName>PSSI_RIS</displayName>
<description>PSSI raw interrupt status register</description>
<addressOffset>0x8</addressOffset>
<size>0x20</size>
<fields>
<field>
<name>OVR_RIS</name>
<description>Data buffer overrun/underrun raw interrupt status</description>
<bitOffset>1</bitOffset>
</field>
</fields>
</register>
<register>
<name>PSSI_IER</name>
<displayName>PSSI_IER</displayName>
<description>PSSI interrupt enable register</description>
<addressOffset>0xC</addressOffset>
<size>0x20</size>
<fields>
<field>
<name>OVR_IE</name>
<description>Data buffer overrun/underrun interrupt enable</description>
</field>
</fields>
</register>
<register>
<name>PSSI_MIS</name>
<displayName>PSSI_MIS</displayName>
<description>PSSI masked interrupt status register</description>
<addressOffset>0x10</addressOffset>
<size>0x20</size>
<fields>
<field>
<name>OVR_MIS</name>
<description>Data buffer overrun/underrun masked interrupt status</description>
</field>
</fields>
</register>
<register>
<name>PSSI_ICR</name>
<displayName>PSSI_ICR</displayName>
<description>PSSI clear interrupt status register</description>
<addressOffset>0x14</addressOffset>
<size>0x20</size>
<fields>
<field>
<name>OVR_ISC</name>
<description>Data buffer overrun/underrun interrupt status clear</description>
</field>
</fields>
</register>
<register>
<name>PSSI_DR</name>
<displayName>PSSI_DR</displayName>
<description>PSSI data register</description>
<addressOffset>0x28</addressOffset>
<size>0x20</size>
<fields>
<field>
<name>BYTE3</name>
<description>Data byte 3</description>
<bitOffset>24</bitOffset>
<bitWidth>8</bitWidth>
</field>
<field>
<name>BYTE2</name>
<bitOffset>16</bitOffset>
</field>
<field>
<name>BYTE1</name>
</field>
<field>
<name>BYTE0</name>
<bitOffset>0</bitOffset>
</field>
</fields>
</register>
</registers>
</peripheral>
... to
STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.productdb.debug_1.xxxxx/resources/cmsis/STMicroelectronics_CMSIS_SVD/STM32H73x.svd
seems to do the trick, no guarantee for correctness, though.
2021-05-17 1:21 AM
Hello there!
STM32CubeIDE only reads an .svd file to display these registers. I will submit a ticket to the responsible team for further analysis and possible correction.
If this is urgent then you can manually add it in the .svd file by default located at:
C:\ST\STM32CubeIDE_1.6.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.productdb.debug_1.6.0.202102151443\resources\cmsis\STMicroelectronics_CMSIS_SVD\STM32H73x.svd
Thanks for bringing it to our attention!
2021-05-17 1:29 AM
Thanks for your quick reply. If i do a
grep -ri PSSI_CFG
in the respective folder it doesn't return anything so it seems to me the interface registers are missing from all svd files.
2021-05-17 2:33 AM
You're correct. The information seems to be missing from the .svd files. I went ahead and created a ticket (internal BZ#107070). The team responsible for the updating of these files have been assigned to the ticket.
2021-05-17 2:55 AM
Adding..
<peripheral>
<name>PSSI</name>
<addressBlock>
<size>0x400</size>
</addressBlock>
<registers>
<register>
<name>CR</name>
<size>0x20</size>
<fields>
<field>
<name>OUTEN</name>
</field>
<field>
<name>DMAEN</name>
</field>
<field>
</field>
<field>
<name>ENABLE</name>
</field>
<field>
<name>EDM</name>
</field>
<field>
<name>RDYPOL</name>
</field>
<field>
<name>DEPOL</name>
</field>
<field>
<name>CKPOL</name>
</field>
</fields>
</register>
<register>
<size>0x20</size>
<fields>
<field>
<name>RTT1B</name>
</field>
<field>
<name>RTT4B</name>
</field>
</fields>
</register>
<register>
<size>0x20</size>
<fields>
<field>
</field>
</fields>
</register>
<register>
<size>0x20</size>
<fields>
<field>
<name>OVR_IE</name>
</field>
</fields>
</register>
<register>
<size>0x20</size>
<fields>
<field>
</field>
</fields>
</register>
<register>
<size>0x20</size>
<fields>
<field>
</field>
</fields>
</register>
<register>
<size>0x20</size>
<fields>
<field>
<name>BYTE3</name>
</field>
<field>
<name>BYTE2</name>
</field>
<field>
<name>BYTE1</name>
</field>
<field>
<name>BYTE0</name>
</field>
</fields>
</register>
</registers>
</peripheral>
... to
2021-06-11 2:58 AM
As a quick update:
This has been corrected and will be part of the next release of STM32CubeIDE.
