Problem where fopen() a bitmap file returns "Not enough space"
Options
2023-12-20 8:57 PM
Hello community,
■Problems occurring:
When I tried to open a bitmap file with the fopen function as shown below,
I encountered a problem that returned "Not enough space".
Do I need to change any settings on the STM32CubeID side?
Please help us solve it.
*1. It has been confirmed that the target directory and file exist.
*2. There is enough free space on C drive.
■Environment:
・Windows
・STM32CubeIDE_1.12.1
・nucleo-f207zgt6
・C language
■Code:
char* path = "C:\\〇〇";
fileName = "C:\\〇〇\\001.bmp";
if (access(path, F_OK) == 0) {
struct stat st;
if (stat(fileName, &st) == 0) {
if ((BmpFp = fopen(filename,"rb"))==NULL) {
// Result of the following processing: Not enough space
char* er = strerror( errno );
exit(1);
10 REPLIES 10
Options
2023-12-26 12:28 AM
Hello Oskar_H
Sorry for the late confirmation.
Thank you, the problem has been resolved.
I was able to open a bitmap with an image on a microSD card inserted into a slot using FATFS.
Thank you for your help in resolving the issue.
- « Previous
- 1
- 2
- Next »
