2021-12-15 12:26 PM
Hi guys! I have a trouble about STMCubeIDE, I installed and created a project, Later, I received this two error ;
c:\st\stm32cubeide_1.8.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_2.0.0.202105311346\tools\arm-none-eabi\bin\ld.exe: cannot open linker script file C:\Users\B??nyamin Terzi\stm\mcu\001MCU\STM32F407VGTX_FLASH.ld: No such file or directory
make: *** [makefile:63: 001MCU.elf] Error 1
If you can help me, I will be pleased.
2021-12-15 01:46 PM
I solved the problem, The program wasn't finding the way, The problem has been solved after I created the file of project in C disk. thank you!
2021-12-15 12:41 PM
Does the file ACTUALLY exist on the path/name listed?
Try using path names without non-ASCII characters.
2021-12-15 01:26 PM
Do you mean the character of file name ?
2021-12-15 01:46 PM
