No ST-LINK detected, Please connect ST-LINK and restart the debug session.
najiranwar
Dear Sir/Mam,
I am facing an issue while using ST-Link V2 in CUBEIDE, it is not detecting and getting an error. but I am able to flash the program in to MCU using cube Programmer.
I also updated ST link drivers. I install every thing in proper manner but not able to flash through CUBEIDE.
While I am using different laptop then it is working fine with same setting, I am not able to understand why it is?
I tried many method but still showing (No ST-LINK detected  Please connect ST-LINK and restart the debug session.)
I have installed all the components in the default directories.
I'm really glad for any suggestion on my issue.
Thanx in advance.
Thanks & Regards
N.Anwar
Kamil Duljas
Senior III
What's board you use? Maybe used wrong usb port on your board :)
Dudo
MM..1
Chief III
You dont describe version IDE, but some  boards stlink require manual upgrade gdbserver part in IDE.
Or your pins is used and config need change connect under reset.
