No source available for "uwTickPrio0 at 0x20000004
sy556
When compiling and debugging with STM32CubeIDE, it shows: uwTickprio0 at 0x200000004 has no available source and the burner is using stlink v2. What is the cause of this problem?
5 REPLIES 5
Imen.D
Hello @sy556 ,
I edited your post to translate it from Chinese to comply with the ST Community guidelines.
If possible, please share more details that can help us to understand and reproduce your issue (which device used? which Cube package and tools version, what do you expect exactly? Are you using a particular Cube example? ....)
Please follow this post on how to write your question to maximize your chances to find a solution:
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/57522
Imen
What I want to ask is, why is this problem: No Source Available for "uwTickprio0 at 0x20000004, how to solve it? The compiler is STM32CubeIDE 1.12.1, and the programming device is ST-LINK.
So no details about your board the connections, or the code..
Please share more details about your hardware and software used.
But first, please make sure to use the latest release of Cube firmware package. CubeMx and CubeIDE.
Imen
Pavel A.
Evangelist III
Likely the program jumped to data (corrupted stack?)
