LL library STM32 OUTPUT compare preload pwm setting enable is unsuccessful,May I ask what is the reason?
Bence
When I set Output compare preload to enable in the configuration interface, the generated code shows disable0693W000001cFw5QAE.png0693W000001cFvvQAE.png
13 REPLIES 13
Ok, I know, thank you. My solution is to enable it again during initialization.
Hi @Nesrine.JLASSI (ST Employee) How to configure to change The TIM_OC_InitStruct.OCState from LL_TIM_OCSTATE_DISABLE to LL_TIM_OCSTATE_ENABLE?
Hi @Bence​
The cc1E bit to which it refers is wired in the driver and activated in the START functions.
it's not STM32CubeMX configuration.
Nesrine
Got it,Thanks!
Best Regards,
Bence
