J-LINK SEGGER with STM32CubeIDE
‎2024-11-04 4:30 AM - last edited on ‎2024-11-04 5:51 AM by mƎALLEm
I would like to know How to configure the J-LINK Segger to work with STM32CubeIDE, after a little searching I found this video : https://www.youtube.com/watch?v=Rf-NKOoPYUc
But at 12:11 I can see this configuration in the video
But I don't have an Application directory :
In this case, do you have an idea how to do it ? Thank you for your helps.
STM32L5 Series
‎2024-11-05 1:32 AM
@Andrew Neil wrote:So what's changed?
If you go back to what you had before, does the connection work again?
It's not the same, at the beginning I converted to J-LINK so I don't know if it's the same configuration :
Now I have an folder and no errors when compiling.
Now my errors is at the end to validate the operation. Now I try to connect
Now when I go into DEBUG mode there is an error, for me it is actually a hardware problem now since when compiling, I compile well with the J-LINK tool.
So do you have any idea now ?
‎2024-11-05 1:37 AM - edited ‎2024-11-05 1:45 AM
@Andrew Neil wrote:This error message:
tells you that it's the basic SWD hardware connection that's failing - it hasn't got as far as anything to do with RTT at that point!
Yes you're right but I have already configured the tool now I will check again to see what it gives. After checking nothing is works
that I try to connect via SWD or JTAG nothing works, so it is normal that STM32CubeMX cannot communicate with the J-LINK
‎2024-11-05 1:55 AM - edited ‎2024-11-05 1:56 AM
@DYann.1 wrote:Yes you're right but I have already configured the tool
So this is not about the tool configuration - it is a basic hardware problem:
Are you also going to complain to Segger about giving you "useless" (sic) links?
When the basic hardware connection is not working, nothing which needs to use that connection can work!
‎2024-11-05 2:07 AM
@Andrew Neil wrote:Your video is about how to set up RTT
The only part of that video which has anything to do with the J-Link itself (the basic hardware connection) is the 28 seconds from 17:18-46 https://www.youtube.com/watch?v=Rf-NKOoPYUc&t=1038s
The rest is all about RTT.
‎2024-11-05 4:31 AM
I don't see your video link but one thing what I am certain is that the connector is compatible with the evaluation card. When I connect with J-LINK and USB_STLK :
Now when I need to only with J-LINK for program and Debug (without USB_STLK) I have this picture :
‎2024-11-05 4:39 AM - edited ‎2024-11-05 4:52 AM
Hi, thank you every body now I can work with my J-LINK . In fact in any case I
I still have to connect USB_STLK even if I don't use ST-LINK (from what I understand).
operation is correct
‎2024-11-05 4:47 AM - edited ‎2024-11-05 4:48 AM
@DYann.1 wrote:I still have to connect USB_STLK even if I don't use ST-LINK (from what I understand).
I'm not clear what you mean by that?
What do you mean by "USB_STLK" here?
You can only have one debug probe attached at a time.
Is this on the EV board, or your custom board?
Show diagrams.
‎2024-11-05 4:54 AM
On my EV board first after I can switch to my real board. "USB_STLK" look on the evaluation card where the connector is located "USB_STLK"
‎2024-11-05 5:16 AM
OK, so that's CN22 - the micro-USB for the on-board ST-Link.
and you're connecting your JLink-EDU to the CN10 JTAG connector:
Yes?
So you're using CN22 to power the board:
- « Previous
- Next »
