2024-11-28 03:05 AM
Hi everyone,
I occasionally run into an error when flashing code to my board using the IDE. The error message is as follows:
Failed to bind to port 61235, error code -1: No error
Failure starting SWV server on TCP port: 61235
Failed to bind to port 61234, error code -1: No error
Failure starting GDB server: TCP port 61234 not available.
Shutting down...
Exit.
This issue sometimes resolves after shutting down and restarting the IDE, but not always. Occasionally, I need to completely reinstall the IDE to get it working again.
Same issue has been discussed earlier by many users, but there doesn’t seem to be a consistent solution or preventive measure.
Does anyone know what might be causing this? Any proven steps to resolve or prevent it?
Thanks in advance for your insights!
2024-11-28 03:51 AM - edited 2024-11-28 03:51 AM
Did you try the latest version of CubeIDE 1.17.0?
