ISM330DHCX - How to use X-CUBE-MEMS1 generated library with SPI?
‎2025-01-24 1:39 AM
Hi
"I am using the STM32F407 to interface with the ISM330DHCX. I have installed the X-CUBE MEMS1 package, configured the SPI1 protocol, and generated the code. However, I have absolutely no idea how to initialize and use the sensor in my main.c code. How should I write the code correctly?" Let me know some suggestions.
- Labels:
STM32CubeIDE
STM32CubeMX
‎2025-01-29 3:30 AM
Hi @Kumar123,
You can refer to this detailed article on How to integrate the X-CUBE-MEMS1 package with your project and also to this article How to install and import an X-CUBE Expansion Package with STM32CubeMX.
Thank you.
ELABI.1
‎2025-01-29 8:54 PM
Hi ELABI.1
"I've written the logic based on the example, but the values aren't being generated as expected."
