Is there a way to communicate between PC(comport) and NUCLEO-H503RB?
LukeJang522
Hi there,
I have NUCLEO-H503RB.
and I want to use comport (uart) between my laptop and H503RB only with usb cable.
I don't want to connect H/W-UART(RX/TX) pins. Is that possible?
Thanks,
On the PC you'd present as a COM port, on the STM32 you'd manage USB packets with "serial" data
6 REPLIES 6
You want to use the ST-LINK's VCP to get USART connectivity
Or use the H5's USB for a CDC Device?
STM32Cube_FW_H5_V1.1.1\Projects\NUCLEO-H503RB\Applications\USBX\Ux_Device_CDC_ACM
Thank you for your answer.
Actually I'm not familiar with USB CDC device.. Can I send/receive the data through this? between PC and NUCLEO board?
Thanks,
Luke.
Thanks, I will figure it out the link that you sent.
Did you figure it out?
Nope, I tried many times but it didn't work properly.
