Is STM32CubeIDE including a simulator in the debug mode?
‎2023-01-13 6:37 AM
I am approaching for the first time with STM32nucleo board and I am using STM32CubeIde. The debug tool provides a simulator to test if the firmware is working properly? I mean a simulation tool like that of MPLAB IDE for PIC microcontrollers which provides a simulation tool in the debug mode. Thank you very much.
Regards.
STM32CubeIDE
‎2023-01-14 10:20 AM
Microcontrollers are deeply embedded and close to input and output stimulus, unless debugging pure sw algo, which points to matlab, running code in ddbug mode onto a nucleo board brings you closer to reality, power condumption, profiling, wcet, esd and emi rating, etc....
‎2023-01-13 8:39 AM
No. You may attach one of the many cheap Nucleo boards or check out Keil MDK software.
hth
KnarfB
‎2023-01-16 1:35 AM
Hello @Zenk91​
In fact, I agree with @KnarfB​ and @S.Ma​ response.
I only want to point to another alternative. QEMU offer some sort of simulator for CortexM. You can find more details on there web site.
Kind regards,
Semer.
‎2023-01-16 1:30 PM
Thanks to all of you for your answers. After trying to work with this board, I realised that effectively it's more immediate to test the firmware with a physical board instead of performing simulations.
Regards.
