I'm using STM32F446RE with STM32Cubeide. After I run my project (in cubeide) STM32F446RE board reads sensors and runs motors. But after I plug out the board and replug it. STM32F446RE does not do those things. Am I loading the code to wrong place(RAM).
‎2022-02-25 11:54 PM
I'm new to Cubeide pls give detail to solution.
Thank you so much.
RAM
STM32CubeIDE
STM32F4 Series
‎2022-02-26 2:23 AM
Only you know where your code is loaded. But let's assume it is in RAM.
What do you think will happen to this code after you plug out the board?
‎2022-02-26 2:26 AM
Code will be deleted and bord won't work.
How can i load the code to ROM. Where is the setting for that in Cubeide?
‎2022-02-26 4:57 AM
Code is loaded into FLASH by default, which is in specified the *_FLASH.ld linker script.
After you power cycle the board, connect with STM32CubeProgrammer and verify the program is in FLASH, which is very likely the case. If it is, there's a bug somewhere. You can connect under debug to determine where the processor is at. If it has power (and NRST is high), it's running something.
‎2022-02-26 5:10 AM
Custom board?
Make sure BOOT0 is pulled LOW​
