HSE clock configuration for nucleo STM32F429zi board at 80MHz
Dushyantsingh
&clk_lsi {
status = "okay";
&clk_hse {
hse-bypass;
clock-frequency = <DT_FREQ_M(8)>; /* STLink 8MHz clock */
status = "okay";
&pll {
div-m = <15>;
mul-n = <96>;
div-p = <2>;
div-q = <4>;
clocks = <&clk_hse>;
status = "okay";
&rcc {
clocks = <&pll>;
clock-frequency = <DT_FREQ_M(80)>; /* highest value to get a precise USB clock */
ahb-prescaler = <1>;
apb1-prescaler = <2>;
apb2-prescaler = <1>;
But the above configuration is not working can you please provide any idea on this.
Issamos
Lead II
Hello @Dushyantsingh
You may take a look at the configuration of HSE bypass in this project.
Best regards.
II
Issamos
Lead II
Best regards.
II
Peter BENSCH
@Dushyantsingh it looks like you are using the NUCLEO-F429ZI with Zephyr, right?
However, your settings are not plausible, because with HSE=8MHz and &pll {div-m = <15>; ...} you only get 533.333kHz. The PLLM output frequency must be at least 950kHz. The current values in &pll{} also result in only 12.8MHz instead of 48MHz at output Q of the main PLL. So you should check your settings again with the RM0090 or CubeMX or CubeIDE.
/Peter
