How to Program and Debug micro STM3203
‎2023-07-02 4:05 AM
I developed a boiard with micro STM32F030C8T6TR. But when I try to create a software in STMcubeMx Build and Debug. I can always build succesfully my project, but When I try to Flash and Debug STcubemxIDE open a popup with wrote, as following reported:
Target connection failed
Target no device found
Error in initializing ST-LINK device.
Reason: No device found on target.
I'm usinf STM32 LINK v2 Debugger, with SWD I respected pinout connection. Following, microprocessor section, taken on the schematics:
And the Debug connector schematics
SomeBody Can help me to understand Why I cannot Flash and Debug, receving error messsage.
‎2023-07-02 4:43 AM
Your schematics is buggy need connet VSSA and VDDA
‎2023-07-02 5:35 AM
But I don't need to use Analog, then VSSA and VDDA are not mandatory.
‎2023-07-02 5:40 AM - edited ‎2023-07-02 5:53 AM
MCU isnt analog as you mean, for example ADC part power on reset or clock oscilator is powered from "analog" as you connect now your MCU is dead
‎2023-07-02 5:53 AM
Ok I tried to connect both of VDDA and VSSA, Can I connet them to VDD e GND? SWD Debug Peripheral need VSSA and VDDA?
Another question NRST need pull-up Resistor?
‎2023-07-02 6:05 AM
Open Nucleo 030 schematics and learn.
‎2023-07-02 6:09 AM
Ok .. Now I tied to connect everythig after that I let you know if I need still help.
‎2023-07-04 2:40 AM
Hello @vdavi81,
Are you still having issues? If not, please close this post by selecting Accept as Solution
