How to deal properly with weak interrupt function and override in assembler ?
bully
I have problems with implementation of weak default function and override with real function in assembler.
I have this in startup.s (usually all functions are defined like this):
.weak      SysTick_Handler
.thumb_set SysTick_Handler,Default_Handler
and then have defined function in main.s:
.global SysTick_Handler
.type  SysTick_Handler, %function
SysTick_Handler:
    push {r3, r4, r5, r6, lr}
if I comment those two lines in startup,s, then proper SysTick_Handler gets triggered, otherwise it ends in Default_Handler. I'm obviously doing something wrong ?
Thanks.
  .syntax unified
  .cpu cortex-m7
  .fpu softvfp
  .thumb
  .section  .text.SysTick_Handler,"ax",%progbits
SysTick_Handler:
  .size  SysTick_Handler, .-SysTick_Handler
3 REPLIES 3
  .syntax unified
  .cpu cortex-m7
  .fpu softvfp
  .thumb
SysTick_Handler:
have tried to replicate your advice, but I still get into Default_Handler.
It doesn't seem to help, I have to comment second line in startup.s.
. Can I check in some output docs what could be wrong ?
//   .thumb_set SysTick_Handler,Default_Handler
And I have this in main.s
SysTick_Handler:
//    adr	r3,LEDSTAT
//    ldr r4,[r3]
//    cmp	r4,#0
    add r8,r8,#1
    cmp r8,#500
    blo RET
    mov	r8,#0    // reset ms counter
    cmp r7,#0    // check flag
	beq LOFF
	mov r5, #LEDs_OFF
//	mov r4,#0
//    str r4,[r3]
    mov r7,#0
	b CONT
Thanks and regards.
