Hi I am beginning using STM32CUbe IDE and I ant to migrate a Keil uBision project where I have a code calling two ASM functions.
HMero.1
these are the functions
__asm void my_strcpy(const char *src, char *dst)
loop
   LDRB r2, [r0] ; Load byte into r2 from memory pointed to by r0 (src pointer)
ADDS r0, #1 ; Increment src pointer
   STRB r2, [r1] ; Store byte in r2 into memory pointed to by (dst pointer)
ADDS r1, #1 ; Increment dst pointer
   CMP  r2, #0 ; Was the byte 0?
   BNE  loop ; If not, repeat the loop
   BX  lr ; Else return from subroutine
__asm void my_capitalize(char *str)
cap_loop
   LDRB r1, [r0] ; Load byte into r1 from memory pointed to by r0 (str pointer)
CMP r1, #'a'-1 ; compare it with the character before 'a'
BLS cap_skip ; If byte is lower or same, then skip this byte
CMP r1, #'z' ; Compare it with the 'z' character
BHI cap_skip ; If it is higher, then skip this byte
SUBS r1,#32 ; Else subtract out difference to capitalize it
   STRB r1, [r0] ; Store the capitalized byte back in memory
cap_skip
ADDS r0, r0, #1 ; Increment str pointer
CMP  r1, #0 ; Was the byte 0?
   BNE  cap_loop ; If not, repeat the loop
The GNU compiler doesnt accept these functions
Please can you tell how to change these functions?
Best regards and thanks in advance
Horacio Merovich
Honestly I despair the state of post-secondary education... is there not someone qualified to lead the course?
/* GNU/GAS Assembler code added into startup.s */
/* extern void my_strcpy(const char *src, char *dst); note parameters backward compared to C */
  .section  .text.my_strcpy
  .type  my_strcpy, %function
my_strcpy:
loop:
  LDRB r2, [r0]   /* Load byte into r2 from memory pointed to by r0 (src pointer) */
  ADD  r0, #1     /* Increment src pointer */
  STRB r2, [r1]   /* Store byte in r2 into memory pointed to by (dst pointer) */
  ADD  r1, #1     /* Increment dst pointer */
  CMP  r2, #0     /* Was the byte 0? */
  BNE  loop       /* If not, repeat the loop */
  BX   lr         /* Else return from subroutine */
.size  my_strcpy, .-my_strcpy
/* extern void my_capitalize(char *str); */
  .section  .text.my_capitalize
  .type  my_capitalize, %function
my_capitalize:
cap_loop:
  LDRB r1, [r0]   /* Load byte into r1 from memory pointed to by r0 (str pointer) */
  CMP  r1, #'a'-1 /* compare it with the character before 'a' */
  BLS  cap_skip   /* If byte is lower or same, then skip this byte */
  CMP  r1, #'z'   /* Compare it with the 'z' character */
  BHI  cap_skip   /* If it is higher, then skip this byte */
  SUB  r1,#32     /* Else subtract out difference to capitalize it  */
  STRB r1, [r0]   /* Store the capitalized byte back in memory */
cap_skip:
  ADD  r0, r0, #1 /* Increment str pointer */
  CMP  r1, #0     /* Was the byte 0? */
  BNE  cap_loop   /* If not, repeat the loop */
.size  my_capitalize, .-my_capitalize
4 REPLIES 4
Pavel A.
Evangelist III
Start by replacing this with standard C library functions, strcpy (or better strncpy) and strupr.
Optimize later, when the project is working.
-- pa
HMero.1
Thanks for your answer
This code is part of a ARM Assembler course so we dont want to use here the standard C library functions.
Best regards
my_strcpy:
loop:
my_capitalize:
cap_loop:
cap_skip:
HMero.1
Hi
Thanks for your contribution to improve our education.
Best regards
Horacio
