Folders missing
‎2025-02-23 10:05 AM
Hello everyone,
I have the problem that only these 2 files are displayed on my Project Explorer. Once testpro and testpro.ioc all other files are missing, for example the C program main.c. My question is can someone help me to fix this problem?
STM32CubeIDE
‎2025-02-24 6:24 AM
Okay so MacOS.
Not sure how the screenshot helps here. Did you try the project menu? Show it
> it says that the code is being generated
Perhaps you need to log in or download the relevant software packages in Help -> Manage Embedded...
‎2025-02-23 10:50 AM
Code must be generated after you configure the IOC file. To generate code, go to Project -> Generate Code
‎2025-02-24 5:56 AM
If i go to project, there is no generate code. And if i go to the bar at the top, it says that the code is being generated, but then nothing comes up.
‎2025-02-24 6:01 AM
welcome to the forum.
Please see: How to write your question to maximize your chances to find a solution.
You haven't given what CubeIDE version you're using, or details of your development Host system.
‎2025-02-24 6:24 AM
Okay so MacOS.
‎2025-02-24 6:45 AM
Ok, I downloaded the software packages. Now it works. Thank you for your help
