Error in final launch sequence - No device on target
‎2025-02-05 3:43 AM
I have a NUCLEO-G491RE board connected to a PC running STM32CubeIDE v1.17.0. On first connection I was prompted to update the firmware on the board, which I did. On successful completion of the update I disconnected and reconnected the board, but the download failed with the attached message.
I have tried several USB cables and also with and without an intermediate USB hub to eliminate these possibilities.
What is the solution please?
STM32CubeIDE
‎2025-02-07 6:12 PM
Problem solved, it was just jumper link settings.
JP5 (5V_SEL): 5V_STLK
JP6 (IDD): On
JP7 (BOOT0): Off
Suggestion, rather than the error messages that are provided, have ones that advise users to check thatthese links are correctly fitted.
‎2025-02-06 12:08 AM
Hello @alw ,
For more investigation, I suggest please that you provide your STM32CubeIDE Project.
Thanks.
Mahmoud
‎2025-02-06 12:50 AM
‎2025-02-06 6:45 AM
Hi Mahmoud,
I hit the limit on private messages.
The only issue I have is that I can't run the application without launching debug, even with selecting Run As STM32C/C++ Application. How do I run without activating debug please?
STMicroelectronics ST-LINK GDB server. Version 7.9.0
Copyright (c) 2024, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
InitWhile : Enabled
Waiting for debugger connection...
Debugger connected
Debugger connected
STM32CubeProgrammer v2.18.0
Log output file: C:\Users\al_wa\AppData\Local\Temp\STM32CubeProgrammer_a02844.log
ST-LINK SN : 0039003C3133511237363734
ST-LINK FW : V3J15M7
Board : NUCLEO-G474RE
Voltage : 3.28V
SWD freq : 24000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x469
Revision ID : Rev X
Device name : STM32G47x/G48x/G414
Flash size : 512 KBytes
Device type : MCU
Device CPU : Cortex-M4
BL Version : 0xD5
Debug in Low Power mode enabled
Opening and parsing file: ST-LINK_GDB_server_a02844.srec
Memory Programming ...
File : ST-LINK_GDB_server_a02844.srec
Address : 0x08000000
Erasing internal memory sectors [0 5]
Download in Progress:
File download complete
Time elapsed during download operation: 00:00:00.326
Verifying ...
Download verified successfully
Target is not responding, retrying...
Shutting down...
‎2025-02-07 2:04 AM
Hi Mahmoud,
I just got the same message about hitting the limit again on private messages
Following one of the other posts I deleted the existing .metadata folder in the workspace so that a new one would be created on launching STM32CubeIDE. I build a simple application based on my Nucleo board (just changing LPUART1 baud rate) and again try to Run As STM32 C/C++ Application. All I want to do download and run the application to the target hardware without invoking the debugger, I never had these problems with previous versions of STM32CubeIDE.
Logging Level : 1
SWD Debug : Enabled
ST-LINK Failed to get target status
Error in initializing ST-LINK device.
Reason: Unknown. Please check power and cabling to target.
‎2025-02-07 2:05 AM
‎2025-02-07 2:06 AM
Jumper link is on 5V_STLK
‎2025-02-07 2:08 AM
And despite the error message I can upgrade the ST-Link as before, so the cable etc. is ok.
‎2025-02-07 5:12 AM - edited ‎2025-02-07 6:25 AM
Hello @alw ,
Further to your comment, I was able to launch the debug session using the STM32CubeIDE Project that you have attached.
I suggest please that you provide the debug configuration.
Thanks.
Mahmoud
‎2025-02-07 5:46 AM - edited ‎2025-02-07 5:48 AM
