2024-07-02 08:21 AM - edited 2024-07-02 08:30 AM
After updating to STM32CubeIDE Version: 1.16.0 Build: 21983_20240628_1741 (UTC), I've noticed that HAL_ADC_Init is being called twice. This behavior is different from the previous version 1.15, where it was called only once. Although the code still functions correctly, it seems less streamlined than before. Could you please review the attached MX_ADCx_Init.c file for potential issues or necessary adjustments?
2024-07-03 12:50 AM - edited 2024-07-03 01:53 AM
Hello @rflamino
I've been able to reproduce this on my side. It does not seem to be a source of problem but I've reported to the concerned team (under internal ticket number 185621) for review on the coming versions.
Best Regards.
STTwo-32.
Hello @rflamino
Best Regards.
STTwo-32.
