Defined symbol no take value
sifour
Hi i have defined a Defined symbol "COST=3" in setting compiler like this
stm32cube color fine the code but during execution it is like if COST=0
you can watch the execution cursor are on the #else (and numBB are = 0)bug stm32 2.png
How can i fix it?
Muhammed Güler
Senior III
You can check it out here.
https://gcc.gnu.org/onlinedocs/gcc/Preprocessor-Options.html
I can recommend you to try making your definition in quotes and using spaces.
2 REPLIES 2
Muhammed Güler
Senior III
sifour
My bad he juste load bad application
