2024-12-20 1:46 AM - last edited on 2024-12-20 2:12 AM by mƎALLEm
hello i downdload latest version but again this error will come when i press migrate or continue option after that iam updating my code in this code goes to error part. fix this problem.
2024-12-27 2:27 AM
hello, I checked it, but I am still facing the same problem
2024-12-27 4:59 AM
A) Sorry, I have hard time to understand - what did you check?
B) build a new project with same .ioc and start debugging - look if you can stop and restart your MCU - RESULT?
Please reply each point - otherwise I will be unable to help
