CubeIDE Memory view - why different fonts?
Why am I getting 2 different fonts in these Memory views?
If I now create a new view, it uses a different font:
It seems that it only happens in a newly-created view; if I switch from that last one to one of the earlier views, then switch back again, it's changed font to the same as the earlier 2:
2 REPLIES 2
Semer CHERNI
Hello @Andrew Neil
First let me thank you for posting.
I made the test but I was not able to see the same behavior.
I made the test with STM32CubeIDE 1.16.1 on a Windows 10 machine.
Are you using the similar setup?
BR,
Semer.
I'm using CubeIDE v1.13.0 on Win 11
Note that it only happens immediately the view is created.
