2019-11-19 12:43 PM
Do they coexist peacefully on one system? Will CubeIDE overwrite any components such as OpenOCD or programmer, or standalone CubeMX data?
Thanks,
-- pa
2019-11-19 1:56 PM
Sounds no issue. If Windows (OS limitation) only one file association (.project / .cproject files) is supported. Latest installed IDE will take benefit of it. Here is only limitation I've faced myself.
2019-11-19 1:56 PM
2019-11-19 3:51 PM
Thank you
