2025-02-06 7:02 AM
我使用STM32F103RBT6的NUCLE板,使用CUBEIDE编译过程中警告如下:
电邮:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-closer.o):在函数 '_close_r' 中:
(.text._close_r+0xc):警告:_close 未实现,并且总是失败
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-lseekr.o):在函数 _lseek_r 中:
(.text._lseek_r+0x10):警告:_lseek 未实现,并且总是失败
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-readr.o):在函数 _read_r 中:
(.text._read_r+0x10):警告:_read 未实现,并且总是失败
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-writer.o):在函数 '_write_r' 中:
(.text._write_r+0x10):警告:_write 未实现,并且总是失败
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:警告:找不到入口符号Reset_Handler;默认为 08000000
已完成的构建目标:batt12.elf
arm-none-eabi-size batt12.elf
arm-none-eabi-objdump -h -S batt12.elf > “batt12.list”
文本数据 bss dec hex filename
96 0 1568 1664 680 batt12.elf
构建完成:default.size.stdout
已完成的构建:batt12.list
22:55:36 构建完成。0 个错误,5 个警告。(耗时 6 秒 387 毫秒)
好像需要使用完成的C库来进行编译。实现应该如何来实现?
2025-02-06 7:11 AM
Hello @candicezhang and welcome to the community.
Not possible to help you with the Chinese language. If you can explain that in English.
Thank you.
2025-02-06 8:50 PM
關於底下四個warning:
可以試著在如下圖所示的linker設定當中將System calls改為 "Do not use system calls from library"將四個warning解除:
關於「警告:找不到入口符号Reset_Handler;默认为 08000000」,請確定在CubeIDE project當中有類似如下的檔案:
2025-02-08 8:07 AM
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-fstatr.o):在函数 '_fstat_r' 中:
(.text._fstat_r+0xe):警告:_fstat 未实现,并且总是失败
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-signalr.o):在函数 '_getpid_r' 中:
(.text._getpid_r+0x0):警告:_getpid 未实现,并且总是失败
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-isattyr.o):在函数 '_isatty_r' 中:
(.text._isatty_r+0xc):警告:_isatty 未实现,并且总是失败
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-signalr.o):在函数 '_kill_r' 中:
(.text._kill_r+0xe):警告:_kill 未实现,并且总是失败
已完成的构建目标:batt12.elf
22056 456 1904 24416 5f60 batt12.elf
已完成的构建:batt12.list
23:56:09 构建完成。0 个错误,9 个警告。(耗时 2 秒 652 毫秒)
E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-closer.o):在函数 '_close_r' 中:
(.text._close_r+0xc):对 '_close' 的未定义引用
(.text._lseek_r+0x10):对 '_lseek' 的未定义引用
电邮:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-readr.o):在函数 _read_r 中:
(.text._read_r+0x10):对 '_read' 的未定义引用
电邮:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-writer.o):在函数 '_write_r' 中:
(.text._write_r+0x10):对 '_write' 的未定义引用
电邮:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-sbrkr.o):在函数 '_sbrk_r' 中:
(.text._sbrk_r+0xc):对 '_sbrk' 的未定义引用
电邮:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.exe:E:/STM32CubeIDE_1.17.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.1.0.202410251130/tools/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/lib/thumb/v7-m/nofp\libc_nano.a(libc_a-abort.o):在函数 'abort' 中:
(.text.abort+0xa):对 '_exit' 的未定义引用
(.text._kill_r+0xe):对 '_kill' 的未定义引用
(.text._getpid_r+0x0):对 '_getpid' 的未定义引用
(.text._fstat_r+0xe):对 '_fstat' 的未定义引用
(.text._isatty_r+0xc):对 '_isatty' 的未定义引用
collect2.exe:错误:ld 返回 1 退出状态
make: *** [makefile:62: batt12.elf] 错误 1
作cao'zuo提示 cao'zu“make -j4 all” 以退出代码 2 终止。生成可能不完整。蒂什0:01:19 构建失败。11 个错误
,1 个警告。(用时 2 秒 968 毫秒)
根据提示作所有的警告变成了错误,方法好像不对呀。
2025-02-08 11:49 PM
最近的ERROR LOG如下:
Caused by: java.net.ConnectException
at java.net.http/jdk.internal.net.http.common.Utils.toConnectException(Utils.java:1028)
at java.net.http/jdk.internal.net.http.PlainHttpConnection.connectAsync(PlainHttpConnection.java:227)
at java.net.http/jdk.internal.net.http.AsyncSSLConnection.connectAsync(AsyncSSLConnection.java:56)
at java.net.http/jdk.internal.net.http.Http1Exchange.sendHeadersAsync(Http1Exchange.java:312)
at java.net.http/jdk.internal.net.http.Exchange.lambda$responseAsyncImpl0$8(Exchange.java:567)
at java.net.http/jdk.internal.net.http.Exchange.checkFor407(Exchange.java:447)
at java.net.http/jdk.internal.net.http.Exchange.lambda$responseAsyncImpl0$9(Exchange.java:571)
at java.base/java.util.concurrent.CompletableFuture.uniHandle(CompletableFuture.java:934)
at java.base/java.util.concurrent.CompletableFuture.uniHandleStage(CompletableFuture.java:950)
at java.base/java.util.concurrent.CompletableFuture.handle(CompletableFuture.java:2372)
at java.net.http/jdk.internal.net.http.Exchange.responseAsyncImpl0(Exchange.java:571)
at java.net.http/jdk.internal.net.http.Exchange.responseAsyncImpl(Exchange.java:423)
at java.net.http/jdk.internal.net.http.Exchange.responseAsync(Exchange.java:415)
at java.net.http/jdk.internal.net.http.MultiExchange.responseAsyncImpl(MultiExchange.java:413)
at java.net.http/jdk.internal.net.http.MultiExchange.lambda$responseAsyncImpl$7(MultiExchange.java:454)
at java.net.http/jdk.internal.net.http.MultiExchange.responseAsyncImpl(MultiExchange.java:444)
at java.net.http/jdk.internal.net.http.MultiExchange.lambda$responseAsync0$2(MultiExchange.java:346)
at java.base/java.util.concurrent.CompletableFuture$UniCompose.tryFire(CompletableFuture.java:1150)
at java.base/java.util.concurrent.CompletableFuture.postComplete(CompletableFuture.java:510)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1773)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642)
at java.base/java.lang.Thread.run(Thread.java:1583)
Caused by: java.nio.channels.UnresolvedAddressException
at java.base/sun.nio.ch.Net.checkAddress(Net.java:137)
at java.base/sun.nio.ch.Net.checkAddress(Net.java:145)
at java.base/sun.nio.ch.SocketChannelImpl.checkRemote(SocketChannelImpl.java:842)
at java.base/sun.nio.ch.SocketChannelImpl.connect(SocketChannelImpl.java:865)
at java.net.http/jdk.internal.net.http.PlainHttpConnection.lambda$connectAsync$1(PlainHttpConnection.java:210)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:571)
at java.net.http/jdk.internal.net.http.PlainHttpConnection.connectAsync(PlainHttpConnection.java:212)
... 24 more
!SUBENTRY 3 org.eclipse.equinox.p2.transport.ecf 4 1002 2025-02-03 11:39:10.376
!MESSAGE Unable to connect to repository https://sw-center.st.com/stm32cubeide/toolchains/9-2020-q2-update/1.12.0/content.xml.xz
!STACK 0
... 24 more
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2025-02-03 11:39:22.469
!MESSAGE Unable to connect to repository https://download.eclipse.org/tools/cdt/releases/latest/compositeContent.xml
!STACK 0
at java.net.http/jdk.internal.net.http.Http2Connection.createAsync(Http2Connection.java:468)
at java.net.http/jdk.internal.net.http.Http2ClientImpl.getConnectionFor(Http2ClientImpl.java:134)
at java.net.http/jdk.internal.net.http.ExchangeImpl.get(ExchangeImpl.java:94)
at java.net.http/jdk.internal.net.http.Exchange.establishExchange(Exchange.java:386)
at java.net.http/jdk.internal.net.http.Exchange.responseAsyncImpl0(Exchange.java:570)
... 21 more
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2025-02-03 11:39:22.490
!MESSAGE Unable to connect to repository https://download.eclipse.org/releases/2023-12/compositeContent.xml
!STACK 0
... 21 more
!SESSION 2025-02-06 13:12:39.410 -----------------------------------------------
eclipse.buildId=Version 1.17.0
java.version=21.0.3
java.vendor=Eclipse Adoptium
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86_64 -data F:\STM
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 4 4 2025-02-06 13:12:54.860
!MESSAGE CubeMX plugin appears to be active, Log4j initialization might be too late.
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 1 1 2025-02-06 13:12:55.133
!MESSAGE Log4j2 initialized with config file F:\STM\.metadata\.log4j2.xml
!ENTRY com.st.stm32cube.ide.mcu.ide 1 1 2025-02-06 13:13:12.831
!MESSAGE Started RMI Server, listening on port 41337
!ENTRY org.eclipse.ui.workbench 4 2 2025-02-06 13:13:30.711
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
java.lang.NullPointerException: Cannot invoke "javax.swing.JComponent.setVisible(boolean)" because "this.webAppContainer" is null
at com.st.microxplorer.plugins.userauth.UserAuth.activatePlugin(UserAuth.java:192)
at com.st.stm32cube.common.mx.userauth.UserAuthAdapter.<init>(UserAuthAdapter.java:29)
at com.st.stm32cube.common.mx.userauth.UserAuthProvider.getUserAuthAdapter(UserAuthProvider.java:16)
at com.st.stm32cube.common.ecosystemintegration.ui.core.MCUEcoSystemIntegrationUiHelper.getUserAuth(MCUEcoSystemIntegrationUiHelper.java:100)
at com.st.stm32cube.ide.mcu.userauth.UserAuthStartup.earlyStartup(UserAuthStartup.java:32)
at org.eclipse.ui.internal.EarlyStartupRunnable.runEarlyStartup(EarlyStartupRunnable.java:79)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:55)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:47)
at org.eclipse.ui.internal.Workbench$39.run(Workbench.java:2762)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.ui 4 0 2025-02-06 13:13:30.719
!MESSAGE Unable to execute early startup code for the org.eclipse.ui.IStartup extension contributed by the 'com.st.stm32cube.ide.mcu.ide' plug-in.
!STACK 0
!SESSION 2025-02-06 21:19:57.113 -----------------------------------------------
java.version=21.0.3
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 4 4 2025-02-06 21:20:33.154
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 1 1 2025-02-06 21:20:33.174
!ENTRY com.st.stm32cube.ide.mcu.ide 1 1 2025-02-06 21:21:22.663
!SESSION 2025-02-09 11:52:52.858 -----------------------------------------------
java.version=21.0.3
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 4 4 2025-02-09 11:53:28.239
!ENTRY com.st.stm32cube.ide.mcu.informationcenter 1 1 2025-02-09 11:53:28.588
!ENTRY com.st.stm32cube.ide.mcu.ide 1 1 2025-02-09 11:53:54.775
!ENTRY org.eclipse.ui.workbench 4 2 2025-02-09 11:54:34.860
!STACK 0
!ENTRY org.eclipse.ui 4 0 2025-02-09 11:54:34.891
!STACK 0
!ENTRY org.eclipse.cdt.core 1 0 2025-02-09 14:13:20.121
!MESSAGE Indexed 'batt12190' (28 sources, 120 headers) in 4.3 sec: 10,623 declarations; 57,428 references; 2 unresolved inclusions; 36 syntax errors; 188 unresolved names (0.28%)
!ENTRY org.eclipse.cdt.core 1 0 2025-02-09 14:15:36.817
!MESSAGE Indexed 'batt12190' (28 sources, 120 headers) in 3.04 sec: 10,623 declarations; 57,428 references; 2 unresolved inclusions; 36 syntax errors; 188 unresolved names (0.28%)
!ENTRY org.eclipse.cdt.core 1 0 2025-02-09 14:16:36.041
!MESSAGE Indexed 'batt12190' (28 sources, 120 headers) in 3.03 sec: 10,623 declarations; 57,428 references; 2 unresolved inclusions; 36 syntax errors; 188 unresolved names (0.28%)
!ENTRY org.eclipse.cdt.core 1 0 2025-02-09 14:24:10.819
!MESSAGE Indexed 'batt12190' (28 sources, 120 headers) in 2.19 sec: 10,623 declarations; 57,428 references; 2 unresolved inclusions; 36 syntax errors; 188 unresolved names (0.28%)
