Could not determine GDB version
MikeMcCormack
I am receiving this message 3 out of 4 times (approximately) after I just "upgraded" the IDE to 1.15.1 while using a Nucleo STM32H563 board.
My debugger config screen looks like
4 REPLIES 4
SofLit
By noticing this :
This example is not available for H5 product. I have a doubt you're using a project not intended to be used for H5.
Could you please check?
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
Is the package downloaded from https://www.st.com/en/embedded-software/stm32cubeh5.html not meant for the STM32H5 family of parts?  My apologies.  I just assumed that since the path below
literally contained the Nucleo board I was using that it was intended for that board.
BTW - how does the name of the project alter the GDB error I was receiving?  Can you tell me how I can fix the GDB problem or not, I'll be glad to change the project name or load another example if you prefer.
You're correct.
Seems the board has that FDCAN examples that I'm not aware of :)!: https://github.com/STMicroelectronics/STM32CubeH5/tree/main/Projects/NUCLEO-H563ZI/Examples/FDCAN/FDCAN_Classic_Frame_Networking
It have been added in newest version of the CubeH5. Was not available in V1.0.0.
Meanwhile I didn't reproduce the issue on a Nucleo STM32H563 with STM32CubeIDE V1.15.1.
Did you update the STLINK firmware?
Yes, following the upgrade to the IDE it indicated that there was newer firmware so I let it upgrade.  I have power cycled the board since then.
