Code generation deletes HAL Drivers
‎2024-09-24 6:27 AM
Hi everyone,
I recently started programming STM Microcontrollers. I'm using STM32CubeIDE 1.13.2 to setup my project.
I want to build a modular software, where some necessary peripherals are initialized from beginning and others are initialized dependend on my build variables.
I was using STM32CubeIDE to setup the project and initialize the peripherals in the .ioc file. That worked well!
The reason I want to build a modular SW is because I also have a modular HW. Sometimes I want to use the same pins for different purposes dependent on my build variables. That is why I want to reset every pin I do not necessarily need from the begining. My problem is occuring when generating the code. The code generation does not only add or delete some code as I configure. It does also delete the HAL drivers if a module is not used. For example if I deactivate ADC it deletes the HAL drivers for adc even if I define them as enabled in the user code space of "stm32l4xx_hal_conf.h". How can I prevent the code generation process from deleting those drivers? I do not want to copy the folder manually or via script every time from my repository.
Is there any solution to keep the driver files?
Thank you very much!
Best regards!
‎2024-09-24 10:10 AM
@DN19 wrote:I don't want to copy the driver files every time I generate the code.
You could automate it as a User Action?
‎2024-09-25 12:38 AM
The adc.c and adc.h in Project/Core/Src and Project/Core/Include persist, but the HAL drivers are deleted. That was what I meant. Please excuse my unclear description.
‎2024-09-25 12:40 AM
Maybe, I don't know. I never used this box before, because its disabled. Nevertheless I would love to try it.
‎2024-09-25 12:53 AM
Thanks a lot for this suggestion. I recently had a look at that post, but this will not fit for my solution. I sometimes also change some common settings in the ioc file (clock or some common GPIOs). And if I adopt this solution, I would have to edit every existing ioc file if I understand it right.
‎2024-09-25 12:58 AM
Yeah, the whole CubeMX/IOC file thing really doesn't support that.
I think you're just going to have to do it manually.
You can always use CubeMX to get you started, but then manage changes manually in the generated code - rather than trying to re-generate.
‎2024-09-25 1:01 AM
Thanks for your answer. So I think my solution to go is just to use the ioc file to set up some new hardware components and afterwards just refreshing the drivers folder manually.
‎2024-09-25 3:57 AM
@DN19 wrote:I never used this box before, because its disabled. Nevertheless I would love to try it.
Apparently it's only disabled within CubeIDE - it should be available if you use the standalone CubeMX:
‎2024-09-25 4:28 AM
It is disabled when creating code for STM32CubeIDE even in the standalone STM32CubeMX.
‎2024-09-25 4:37 AM
Oh well - I guess that must've changed since 2021, then?
Why is it still there if it's never enabled?!
- « Previous
- 1
- 2
- Next »
