Can't configure Serial Audio Interface (ioc) with STM32CubeIDE 1.18.0
‎2025-03-30 6:29 PM
With the latest STM32CubeIDE 1.18.0 (I tried on Mac and Windows), on a brand new project for a STM32H7B0VBT6 mcu. In the ioc, if I try to enable the SAI1 (or SAI2) it let me choose the mode for both SAI A and SAI B but the configuration panel is empty, it also shows a spinning icon when clicking on SAI1 again. I attached a screenshot for reference. Everything else seems fine (I2S, I2C, SPI, ADC, etc).
Any help is welcome! Thank you!
- Labels:
Bug-report
STM32CubeIDE
‎2025-04-14 8:40 AM
Hello @octave and welcome to STCommunity;
Could you please try to use the latest STM32CubeMX 6.14.1 version and/or STM32CubeIDE1.18.1 version.
The SAI tab configuration issue is fixed as mentioned in STM32CubeMx 6.14.1 released.
Please let me know if the issue is solved or not?
Thank you.
Kaouthar
‎2025-03-30 9:58 PM
- The issue is with STM32CubeMX V6.14.0 / STM32Cube FW_H7 V1.12.1
- It works fine with STM32CubeMX V6.10.0 / STM32Cube FW_H7 V1.11.2
‎2025-03-30 11:02 PM - edited ‎2025-03-30 11:06 PM
Yes, same as on H7A3 , already known problem.
H7A3 and B are same chip, probably.
Just on H743 all this working fine.
So seems to be a problem only on H7A/B .
‎2025-03-31 8:23 AM
Thank you, I hope it gets fixed soon!
‎2025-03-31 10:47 AM
@KDJEM.1 Do you know when it will be fixed?
‎2025-04-14 8:40 AM
Thank you.
Kaouthar
‎2025-04-18 9:24 AM
Thank you! Yes it works!
