AScha.3
Mar 28, 2025 09:09 UTC
on H7A3 no SAI configuration in Cube - Bug report
big surprise: when activating SAI on H7A3ZIT , no configuration possible : ...nothing to configure...
+ on IDE 1.18.0 , with newest Cube package: 1.12.1
+ on H743ZIT , looks as it should:
... V1.12.2  coming then ?
- or "manual setting needed ? on H7A3 it makes then: (ignoring the warning about SAI not correct set)
static void MX_SAI1_Init(void)
 /* USER CODE BEGIN SAI1_Init 0 */
 /* USER CODE END SAI1_Init 0 */
 /* USER CODE BEGIN SAI1_Init 1 */
 /* USER CODE END SAI1_Init 1 */
 hsai_BlockA1.Instance = SAI1_Block_A;
 hsai_BlockA1.Init.AudioMode = SAI_MODEMASTER_TX;
 hsai_BlockA1.Init.Synchro = SAI_ASYNCHRONOUS;
 hsai_BlockA1.Init.OutputDrive = SAI_OUTPUTDRIVE_DISABLE;
 hsai_BlockA1.Init.NoDivider = SAI_MASTERDIVIDER_ENABLE;
 hsai_BlockA1.Init.FIFOThreshold = SAI_FIFOTHRESHOLD_EMPTY;
 hsai_BlockA1.Init.AudioFrequency = SAI_AUDIO_FREQUENCY_192K;
 hsai_BlockA1.Init.SynchroExt = SAI_SYNCEXT_DISABLE;
 hsai_BlockA1.Init.MonoStereoMode = SAI_STEREOMODE;
 hsai_BlockA1.Init.CompandingMode = SAI_NOCOMPANDING;
 hsai_BlockA1.Init.TriState = SAI_OUTPUT_NOTRELEASED;
 if (HAL_SAI_InitProtocol(&hsai_BlockA1, SAI_I2S_STANDARD, SAI_PROTOCOL_DATASIZE_16BIT, 2) != HAL_OK)
 Error_Handler();
 /* USER CODE BEGIN SAI1_Init 2 */
 /* USER CODE END SAI1_Init 2 */
KDJEM.1
KDJEM.1Best answer
Apr 14, 2025 15:42 UTC
Hello @AScha.3 ;
The SAI tab configuration issue is fixed as mentioned in STM32CubeMx 6.14.1 released.
Could you please try to use the latest STM32CubeMX 6.14.1 version and/or STM32CubeIDE1.18.1 version and let me know if the issue is solved or not?
Thank you.
Kaouthar
KDJEM.1
Mar 28, 2025 09:41 UTC
Hello @AScha.3;
Similar issue is reported here.
This issue has been raised internally to dev team for fix.
Internal ticket number: 204851 (This is an internal tracking number and is not accessible or usable by customers).
Thank you.
Kaouthar
AScha.3
AScha.3Author
Mar 28, 2025 10:33 UTC
Hi, @KDJEM.1  ,
similar ...but new. Or new old recovered, because on last Cube 1.11.2 :
it was ok, at least SAI :
--- but SWV not working here at all !
here sending on SWO in main loop - nothing comes to console, no profiling also:
btw on H743ZIT its working , profiling also.
ed with recent Cube/HAL v1.12.1 , after maybe 30 times (!!!!) click on start trace SWV, its working:
So this is the well known state of SWV on STM's IDE . fine.
KDJEM.1
Mar 28, 2025 10:50 UTC
Hello @AScha.3;
For the missing SAI configuration, this is a new issue detcted after upgrading to STM32CubeMX 6.14.0 and/or to STM32CubeIDE 1.18.0 versions.
I apologize for any inconvenience. I come back to you when the issue is fixed.
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Hello @AScha.3 ;
Thank you.
Kaouthar
alfsch
Apr 15, 2025 20:09 UTC
Hello @KDJEM.1  ,
just because i cannot login as @AScha.3  , with my private login here ...
Now i updated to IDE 1.18.1 , and voila ... SAI configuration on H3A seems ok.
Code generated, compiler : no errors.
