Building .bin file CubeIDE
2021-10-18 11:23 AM
My CubeIDE project currently builds a debug .elf and I am trying to build a .bin file instead. In order to do this, I researched the forums that say I need to go to project properties: C/C++ Bulild->Settings->Tool Settings->MCU Post Build outputs and select "convert to Intel Hex file".
(https://community.st.com/s/question/0D50X0000AlgEerSQE/how-to-generate-bin-file-after-building-with-cubeide)
I am not sure how to actually build the project in order to build the bin file. Should I select the "Build Release" option through the CubeIDE build icon? When I do this, I get a bunch of errors about header files not being found.( I don't get these errors when I build the debug project). What am I doing wrong? Thanks
STM32CubeIDE
2021-10-18 11:34 AM
BIN file will be created if you have "Convert to binary file" checked. A HEX file will be created if you have "Convert to Intel Hex file".
Build it normally either through Debug or Release configuration and those files will be created after it successfully builds.
Sounds like your Release configuration has errors. You'll need to fix those if you want to create a Release build.
