bug report: STM32F302CBT6 failed to compile
BVauc.1
Hi, This particular MCU is not fully populate in project generator, the result when trying to create a project is incomplete project that can't compile. I worked-around by selecting a different MCU, but as migrating between MCU is not supported, I am facing a wall, and I don't know how to workaround.
Thanks for you attention! Bernard
3 REPLIES 3
Imen.D
Hello @BVauc.1​ ,
Please share your ioc file to check your project, maybe it is not set up properly.
What do you mean migrating between MCU is not supported ? Did you search and select "List Pinout Compatible MCUs" from the Pinout menu ?
Best Regards,
Imen
Imen
BVauc.1
Hello, thanks for checking, it was an automatic update just now that seems to solve the issue, if you are at this initiative, thank you, it works now.
BVauc.1
What I mean by migrating: once a project is created in CubeIDE, there is no possible to replace the MCU type by another type. Is it correct?
