Binary output code
EBris.2
Hi all,
I'm working on TouchGFX project that uses external QuadSPI Flash to store all graphics objects required by my designed HMI.
I want to obtain as result of the release building two distinct .bin files that contain respectively:
  • one bin file that contains the binary code of my application to be written into internal flash,
  • and a second bin file that contains the graphics objects to be written into external QuadSPI Flash.
Is there a way into STM32CubeIDE to do that?
Thank you in advance!
2 REPLIES 2
I'd imagine objcopy has options to selectively extract sections.
Can do so with FromELF in Keil, and the ELF format is not that complicated in the fixed/frosted forms used here.
I'd probably build my own signing tools to validate the integrity of the external data/images so the system doesn't drive into a ditch when things are corrupted.
EBris.2
Hi clive1,
Thank you so much for your advice!
I have resolved by adding arm-none-eabi-objcopy command in Post-build steps section properties of my project.
