2020-06-05 12:42 PM
Even copying and pasting my *.h & *.c files into my new project CUBE IDE does not accept these files, issuing: "No such file or directory" and aborting the compilation. What should I do?
My bult: Version: 1.3.1
Build: 6291_20200406_0752 (UTC)
2020-06-05 3:52 PM
Generally, you place them in the same directory as main.c and main.h, although you can put them elsewhere if you tell the IDE about those directories. Drag/drop into the directory should work.
2020-06-11 8:27 AM
Thanks for your answer.
In spite of we have the explained two ways to insert customer files, the drag & drop method seems to produce less "warning" messages.
