4 ADCs simultaneous sampling
AKhot.1
Is it possible to use 4 ADC input channel and sample them simultaneously in any of the STM32 product on a single board?
6 REPLIES 6
MasterT
Lead
No. To sample 4 analog inputs at ones you need 4 ADC, check out nucleo-G474re
raptorhal2
Lead
The F303 also has 4 ADCs.
As I recall this could be done on the F3-DISCO board. ie ADC1 and 2, and ADC3 and 4, could be paired and synchronized with a common clock trigger. Data Buffering perhaps not ideal, but could be managed.
https://www.st.com/en/evaluation-tools/stm32f3discovery.html
You are saying that it's impossible and then immediately suggesting a device, which can do it...
I know how to operate ADC1 and ADC2 together similarly this will work for ADC3 and ADC4. But how to do all 4 simultaneously? You said we can do that by common clock trigger.
Do you have example for that? Or do you know how to do that?
Simply set the same event to trigger all ADC.
hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIG_T1_TRGO;
Here is an example for G-474, search another one for your uCPU
https://github.com/STMicroelectronics/STM32CubeG4/blob/master/Projects/B-G474E-DPOW1/Examples/ADC/ADC_GainCompensation/Src/main.c
