2024-04-17 1:41 PM - last edited on 2024-04-30 8:23 AM by Amel NASRI
I am not sure how to categorize this problem. I have a custom board that I had done an initial software development cycle on STM32CubeIDE. I am working a newer version in VSCode with the STM32 Extension. Everything is working with the exception of one problem. I am using a watchdog on my MCU (STM32L4R9ZGJ6), which triggers while I have the processor halted. I know how to fix this in CubeIDE (Debugger tab, Enable Suspend Watchdogs) but cannot figure it out on the VSCode/GDB side. Below is the launch.json I have so far:
"version": "0.2.0",
"configurations": [
"cwd": "${workspaceFolder}",
"executable": "./build/debug/build/test.elf",
"name": "Debug with ST-Link",
"request": "launch",
"type": "cortex-debug",
"runToEntryPoint": "main",
"showDevDebugOutput": "none",
"servertype": "stlink"
"name": "Launch",
"type": "cppdbg",
"program": "${command:cmake.launchTargetPath}",
"MIMode": "gdb",
"miDebuggerPath": "${command:vscode-embedded.st.gdb}",
"miDebuggerServerAddress": "localhost:3333",
"debugServerPath": "${command:vscode-embedded.st.gdbserver}",
"debugServerArgs": "--stm32cubeprogrammer-path ${command:vscode-embedded.st.cubeprogrammer} --swd --port-number 3333",
"serverStarted": "Waiting for connection on port .*\\.\\.\\.",
"stopAtConnect": true,
"postRemoteConnectCommands": [
"text": "load build/debug/build/UPADermitron.elf"
"logging": {
"engineLogging": true
"preLaunchTask": "Build",
"svdPath": "${command:vscode-embedded.st.svd}/STM32L4R9.svd"
Any help is appreciated! Sorry if this has come up but I have tried to find with no luck.
