STM32 VS Code Extension (No compiler found in cache file)
‎2023-08-21 12:55 PM
I am trying to get the STM32 VS Code Extension working on my macOS (Ventura 13.2.1). I have installed STM32CubeCLT and STM32CubeMX. I can compile my project successfully using the build command command. However when I press on the debug icon on the bottom toolbar, I get an error saying that "No compiler found in cache file Source Make Tools (Extension)" (See attached screenshot). I have examined the build/debug/build/CMakeCache.txt file and everything looks ok at first glance. Any insight or solutions as to what is going on would be welcomed.
VSCode for STM32
‎2025-02-17 6:24 AM
Hey there,
I am running into the same issue. has it been resolved yet?
Greetings Marcus
‎2025-03-10 10:03 AM
I can also confirm that I am having the same problem.
‎2025-03-11 1:44 AM
Hello @3subzero3, @MM1, @Javier1, @userst
Are you all using a MacOS?
‎2025-03-11 6:15 AM - edited ‎2025-03-11 6:15 AM
same issue here on Windows 10
‎2025-03-11 7:41 AM
I am on a Mac (Sequoia 15.3)
‎2025-03-13 1:34 AM
‎2025-03-18 4:15 AM
Windows 11 Enterprise.
- « Previous
- 1
- 2
- Next »
