STM32CubeIDE Serial Console in use
‎2020-06-18 4:47 AM
I am stuck at step 6 in
MPU Serial Console is operational, ethernet RJ45 also, and serial port is not opened elsewhere.
I don't get passed this yellow light, "serial consol in use"
/Peter
- Labels:
ST-Boards
STM32CubeIDE
STM32MP15 Lines
‎2020-06-18 5:04 AM
​Hi @PeterL​
You screenshot is normal. You have indeed the serial console open.
Close it to see the widget status move to green
Olivier
‎2020-06-18 5:57 AM
Hi @Community member​
Closing Console does not cause widget to change... For me.,.
/Peter
‎2020-06-18 6:05 AM
@Community member​ , OK I assumed closing console was either using the tab cross or disconnect then tab cross. Neither worked. But there was another way to close. Using a cross located outside the tab, at the right end of the title window. Strangely that behaved differently than the tab cross.
Now it worked. Really odd way to close a tab...
/Peter
‎2020-06-18 6:12 AM
@Community member​
Got stuck at next step immediately...
There is an error message blocking me from debug. The label "Connection" in frame header is blinking...
/Peter
‎2021-11-03 2:38 AM
When there is both an STLink connection and FTDI connection, then FTDI is chosen by CubeIDE. My problem is that FTDI port is not a linux console, but an application proprietary port.
At Window | preferences | STM32Cube | MPU Serial there seem to be a feature to choose a preferred com-port, but that is without effect for me.
I can see that wrong port is selected and fails to open since I have putty already opened the FTDI com port.
