TIM2_CH2 PWM not work
guansonghuang
hello,st friends.
   My board use TIM2_CH1 pwm to drive a led.
dts configure as:
but the led can not light on.use these command
byw: I use gpio test led hardware is ok
Jean-Marc S
Hello
We discovered an issue in the Datasheet of the MP13.
It will be described in an errata and DS updated soon.
The TIM2_CH1 and TIm2_ETR are not available on all GPIO as listed currently on DS:
The correct settings are:
  • PA0, PA15, PD3, PG8 only TIM2_CH1
  • PE2, PF13, PE15 only TIM2_ETR
  • PA5 both TIM2_CH1, TIM2_ETR
so in your case PF13 only supports TIM2_ETR.. not TIM2_CH1
JM
8 REPLIES 8
Sarra.S
Hello @guansonghuang
Verify that the PWM is exported correctly, you should see pwm0 listed using
ls /sys/class/pwm/pwmchip0
 Also, try using an oscilloscope or logic analyzer to verify that the PWM signal is being generated on the correct pin (PF13)
hi @Sarra.S
I use oscilloscope vefify no pwm out on PF13;
but
1、if change pwm channel1 to PA5.that is ok
2、Enable all 4 pwm out,all other 3 pwm output correctlly excpt for PF13
guansonghuang
I verify TIM2_CH1 bare metal using PF13.  it is the same result as linux not working.
So  I assume that PF13 can not be assigened to TIM2_CH1.
please help to double check this. thank you
Jean-Marc S
Hello
JM
guansonghuang
Thank you very much
if errata release,please notify me
Jean-Marc S
ok
Hello
Please note that the updated errata sheet is now available on st.com
https://www.st.com/resource/en/errata_sheet/es0539-stm32mp131x3x5x-device-errata-stmicroelectronics.pdf
JM
