TIM2_CH2 PWM not work
2024-09-05 2:50 AM
hello,st friends.
My board use TIM2_CH1 pwm to drive a led.
dts configure as:
but the led can not light on.use these command
byw: I use gpio test led hardware is ok
- Labels:
STM32MP13 Lines
2024-09-09 1:41 AM
Hello
We discovered an issue in the Datasheet of the MP13.
It will be described in an errata and DS updated soon.
The TIM2_CH1 and TIm2_ETR are not available on all GPIO as listed currently on DS:
The correct settings are:
- PA0, PA15, PD3, PG8 only TIM2_CH1
- PE2, PF13, PE15 only TIM2_ETR
- PA5 both TIM2_CH1, TIM2_ETR
so in your case PF13 only supports TIM2_ETR.. not TIM2_CH1
JM
2024-09-06 1:32 AM
Hello @guansonghuang,
Verify that the PWM is exported correctly, you should see pwm0 listed using
ls /sys/class/pwm/pwmchip0
Also, try using an oscilloscope or logic analyzer to verify that the PWM signal is being generated on the correct pin (PF13)
2024-09-06 1:50 AM - edited 2024-09-06 1:59 AM
hi @Sarra.S
I use oscilloscope vefify no pwm out on PF13;
but
1、if change pwm channel1 to PA5.that is ok
2、Enable all 4 pwm out,all other 3 pwm output correctlly excpt for PF13
2024-09-08 7:08 PM
I verify TIM2_CH1 bare metal using PF13. it is the same result as linux not working.
So I assume that PF13 can not be assigened to TIM2_CH1.
please help to double check this. thank you
2024-09-09 1:41 AM
Hello
JM
2024-09-09 4:02 AM
Thank you very much
2024-09-09 4:39 AM
if errata release,please notify me
2024-09-09 5:01 AM
ok
2024-10-01 12:58 AM
Hello
Please note that the updated errata sheet is now available on st.com
JM
