2021-01-05 11:04 AM
Strange issue
used power supply 24v, 5A
If we connect debug 3.5 MM cable on debug port, then only unit boots up and taking to kernel command line prompt else it does not boot up
I tried taking out LCD display , USB, battery, still above issue there
its a customized board,
help me to diagnose
2021-01-11 08:58 AM
as it is custom board, we need more information to help you. I think you already done some investigation and results. We could answer only to precise questions on a specific STM32MP1 behavior.
Regards.
2021-01-11 09:06 AM
its a junk character received , when physical debug cable,
i bypass this scenario in uboot , now working
