2022-02-23 7:31 AM
For example, in the KEIL uVision 5 IDE, it is possible to specify the starting address in the "Options for Target" window. I would like to know how to do the same in Cube IDE
2022-02-24 4:53 AM
Your ask isnt perfect , bootloader dont need change start address. But ofcourse app part need it and in CubeIDE you need edit linker ld file, and in system files vector table offset.
