2022-03-25 09:46 AM
Is there any way to disable and enable all interrupts in a assembly way, because i need to manually switch on and OFF particular GPIO before UBOOT SPL start
uboot-source/board/st/stm32mp1/board.c
void board_debug_uart_init(void)
// disable interrupts ---- need support here
//PWM self logic written
// enable interrupts ---- need support here
2022-04-15 05:47 AM
Hi @Ara.1
is that you asked for ?
void Enable_Irq(void)
unsigned long temp;
__asm__ __volatile__("mrs %0, cpsr\n"
"bic %0, %0, #0x80\n"
"msr cpsr_c, %0"
: "=r" (temp)
: "memory");
void Disable_Irq(void)
unsigned long temp;
"orr %0, %0, #0x80\n"
"msr cpsr_c, %0"
: "=r" (temp)
: "memory");
void Enable_Fiq(void)
unsigned long temp;
"bic %0, %0, #0x40\n"
"msr cpsr_c, %0"
: "=r" (temp)
: "memory");
void Disable_Fiq(void)
unsigned long temp;
"orr %0, %0, #0x40\n"
"msr cpsr_c, %0"
: "=r" (temp)
: "memory");
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
