Where is updated stLinux User Manual ? UM1535,UM1538 very old, not for STM32MP157? Because want information how to access TIM12_CH1 is doing pwm okay test in sysfs, but want to use it for a timer interrupt handler in application, example code please.
DYenEmbedded
OlivierK
Hi DYenEmbedded (Community Member)
The User manual that you refer were transposed to our st wiki
https://wiki.st.com/stm32mpu/wiki/Main_Page. It's search engine is quite powerful.
For instance:
https://wiki.st.com/stm32mpu/wiki/PWM_overview#Sysfs_interface
Did you update your DT inside the timer node with the pwm subnode?
pwm {
compatible = "st,stm32-pwm";
#pwm-cells = <3>;
interrupts = <GIC_SPI 119 IRQ_TYPE_EDGE_FALLING>; // Example interrupt configuration
can you list it onboard ? cat /proc/interrupts ?
Rgds,
Olivier
