STM32 MCUs
From FAQs to complete How-to articles, find useful articles on STM32 MCUs programming, troubleshooting, ecosystem, and product details.
Knowledge base articles
What option bytes in STM32 are, and how to use them
All STM32 have options and even though the functionalities may vary among the different families and series, they are all meant to allow the user a way to customize the general settings of the microcontroller. Option Bytes are mostly used to pre-conf...
Increased consumption in low power modes
Power consumption in low power mode is higher than expected. Problem remains after reset, but is solved by power cycling the MCU. What is the problem? Issue can be caused by debug in low power mode option. When developers debug their code in low-powe...
How to use the STM32’s backup registers
Introduction Some of the STM32 microcontrollers have backup registers. These registers can be written/read and protected and have the option of being preserved in VBAT mode when the VDD domain is powered off. In this article we will learn how write, ...
STM32 MCU reference manuals: Expected preliminary updates
Introduction This article includes preliminary updates of STM32 MCU reference manuals reported since 1st January 2024. It highlights the current description requiring update and the expected one if available. The purpose of this article is to delive...
KDJEM1_0-1776956703820.png KDJEM1_1-1776956738384.png KDJEM1_2-1776956764453.png KDJEM1_3-1776956794075.png
KDJEM.1 by ST Employee
  • 6035 Views
  • 0 comments
  • 8 kudos
STM32 MCU datasheets: Expected preliminary updates
Introduction  This article includes preliminary updates of STM32 MCU datasheets reported since 1st January 2024.  It highlights the current description requiring update and the expected one if available. The purpose of this article is to deliver any...
ImenD_0-1759388395256.png ImenD_0-1767705991417.png ImenD_0-1751620841076.png ImenD_1-1751620864116.png
Imen.D by ST Employee
  • 7229 Views
  • 0 comments
  • 7 kudos
STM32 MCU errata sheets: Expected preliminary updates
Introduction This article includes preliminary updates of STM32 MCU errata sheets reported since 1st January 2024. It highlights the current description requiring update and the expected one if available. The purpose of this article is to deliver an...
KDJEM1_1-1712142798747.png KDJEM1_0-1733228672726.png KDJEM1_1-1733228771070.png
  • 4857 Views
  • 0 comments
  • 5 kudos
How to Quick Connect STM32U5 to Azure IoT Central
A step-by-step guide to connect and publish real B-U585I-IOT02A Discovery Kit sensor data to a free Azure IoT Central Application.STM32U5 Azure Quick Connect - Getting Started Guide STM32U5 Azure Quick Connect is the fastest way to get your B-U585I-I...
How to check compatibility on USB ULPI transceivers with STM32 MCUs
Introduction Some external USB HS PHYs compatible through the ULPI interface are detailed in Table 12, compatible USB HS PHY in AN4879. However, not all transceivers could be listed in the application note. Compatibility checking is necessary before...
FBL by ST Employee
  • 2905 Views
  • 0 comments
  • 5 kudos
