2024-02-28 5:24 AM
I am trying to make sniffer for STM32WB BLE application work, (ref: https://wiki.st.com/stm32mcu/wiki/Connectivity:STM32_Sniffer_for_BLE_Setup_guide). I am stuck at step 4.1. I am unable to get "STM32WB sniffer interface" on Wireshark. I tried uninstalling and reinstalling all software, but no luck.
Thanks in advance for help!
2024-03-01 3:08 AM
Just to confirm, have you properly programmed your board(s) (step 3)? Are they properly connected to the PC and the COM port recognized?
BR, Joé
2024-03-07 10:44 AM
Hello Joé,
I looked into the device manager. I see that "STMicroelectronics Virtual COM Port (COM7)" shows
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
Is this the problem? I tried re-programming (both firmware and stack) the MCU and re-installing Wireshark, but no luck.
Please help!
Soumadeep De
2024-12-10 1:39 AM
I ran into the same problem that the hardware platform is NUCLEO-WB55RG.I followed the https://wiki.stmicroelectronics.cn/stm32mcu/wiki/Connectivity:STM32_Sniffer_for_BLE_Setup_guide#Programming_the_board wiki step by step.The wireshark version is 4.4.2, based on windows11.
Sniffer interface do not appear.
I saw a solution to this problem in the wiki and tried again, but the problem still existed.
How do I know that the sniffer protocol stack is started properly? There is no corresponding file/wiki to explain what happens when the sniffer firmware starts.
Please help!
Mr Wu
